Old 08-31-2005, 07:39 PM
wvrefugee wvrefugee is offline
Engine swap question.
Hello all...
I am looking to replace the engine in my 95 Jimmy 4.3 4wd. My question is what year(s) gmc engine will fit. I found one out of a 96 model also one out of a 94 w/ low miles. I want to make sure before I dish out the $$ that either will fit.
Any help here will be greatly appreciated.
Old 08-31-2005, 08:36 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Engine swap question.
95 only.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-01-2005, 05:50 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
If your ECM is under the hood, you can upgrade to the 96-98 engine pretty easily...You'll need
ECM
Harness
Engine...
All related sensors
May or may not have to add an addition 02 sensor to the mix.
Everything is pretty much plug in play. If you don't want to swap the ecm and harness you can use the 92-95 regular CPI motors. If you obtain a regular CPI motor with the top post mount distributor and you have the side post mount distributor on your existing engine you will have to move the following from your old engine.
Lower intake
Distributor
Reluctor wheel
All related sensors
Old 09-01-2005, 08:16 AM
herkyhawki herkyhawki is offline
Is your '95 OBD2? Where is the ECM? Does it have a crank position sensor (in bottom of timing cover)? If not, then go for the '94 engine.
General rules, (which means there are exceptions):
An "early 1995" will be same as 1994.
A "Late 1995 will have block,pistons,crank of a 1996, and heads/intake/CPI of a 1994.
Old 09-03-2005, 06:45 PM
Justa thank you...and a ?
I'm kinda financially strapped right now. I'm thinking of replacing the cpi, (second time) and hoping that will do. After 265,000 miles I was flirting w/ a another engine. After looking in to it, maybe not! $$ Also tranny is shot, but I have one located.
Engine was very strong before I parked it. I knew it was the cpi, same exact symptoms of last time, and the tranny was going.
Would you fix this thing, lots of engine work (cpi & prob. a little more), new transmission. 265k miles....other than that it is very well maintained since it was new. Body & interior perfect.
Thanks for your input. Much appreciated!
Old 09-04-2005, 12:07 AM
BlazerLT's Avatar
AF -Advisor
Can you please supply ALL informatio.
What is it doing now?
Just because it is running bad doesn't mean you have to replace it.
