Old 08-31-2005, 06:26 PM
oddcar88 oddcar88 is offline
1993 Lumina Stalling
Recently I bought a used Chevy Lumina. It starts fine runs.....then at a light i press the brake and the front end shakes, shakes and the engine shuts off. I would restart it in the middle of the road and it works fine until i put in reverse, drive, 2 or 1 gears. then i shuts off again as it did in the first place. The only way to get it off the road is to turn it on let it idle for like 5-10 minutes and put it in gear. Even then it shakes alittle as I decelerate and if I stop it will turn off again. So i have to quickly get to a park or field and let it idle for a while then go home. Please HELP ME!! I want to be able to drive to work without worring if my car will stall. Also if this has anything to do with it when ever i get gas and I take to cap off I hear a suction sound like someone sucked the air out of my gas tank.
Old 08-31-2005, 07:51 PM
jsgold jsgold is offline
Sounds like a familar problem with most GMs. The TCC solenoid goes bad or gets clogged and when it gets hot it causes the transmission to act up. The car shakes and shudders and acts like a standard shift car in high gear going slow. Stalls out. Car starts fine but will stall as soon as shifted into ANY gear. When it cools down a bit it will work again for a while. This locks the torque converter and when it goes bad it won't release. Usually hard to fix on Lumina/Corsica due to location. A cheap part (<$30) but can cost 150-250 to replace, as most transmission shops insist on a total flush of the system to keep the new one from clogging. You can unhook the TCC and it will work OK, except, you will have lower mpg. Not a lot though. Most people unhook them and forget them. Up to you. Assuming yours is a 3.1 it should be under your air filter housing. Remove the filter, cover, and then the housing. Look underneath for a 4 pin connector. Unplug it and try it out. If it works OK you are done, unless you choose to fix it later. On some cars this won't help, such as 4 speed transmissions on Buicks etc., but should do the trick on yours.
If these symptoms are not same as yours you could have other problems, but, most of the ones I can think of occur whether in gear or not.
I used to be indecisive, now I am not so sure.
