Old 08-31-2005, 06:05 PM
WasteGas's Avatar
WasteGas WasteGas is offline
Question Wet sanding
What's your methods of wet sanding
Thanks in advance
Old 08-31-2005, 06:18 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Sandpaper and water, rub gently. What do you want to know?
PHOTOBUCKET SUCKS
Old 08-31-2005, 06:25 PM
WasteGas's Avatar
Re: Wet sanding
So you just simply dip the sandpaper in water? I'm just curious because I have never wetsanded before.
Thanks for the reply
Old 08-31-2005, 06:29 PM
chyknees chyknees is offline
Re: Wet sanding
i just run the faucet in my sink and go to town...keeping the model wet at all times and just sand away.
Old 08-31-2005, 06:58 PM
freakray freakray is offline
AF Modelrater
Re: Wet sanding
Highlights from using the search feature:
http://www.automotiveforums.com/vbul...ht=wet+sanding
http://www.automotiveforums.com/vbul...1135963&page=1
AF User Guidelines
Old 08-31-2005, 08:40 PM
Hawk312 Hawk312 is offline
Re: Wet sanding
Use a little dish detergent in the water...just a little. Watch the edges, as you will rub through them first. Make sure the surface is clean before you start, and stays contaminant (dust, dirt) free as much as possible. Work slowly, and check often by drying the area from time to time.
WANTED! 1/12 Corvettes and Camaros.
Newest builds. Click on images to go to the thread:
1/12th `69 Z/28 Camaro and 1/12 `67 Corvettes
Old 08-31-2005, 08:42 PM
AstroRide44's Avatar
AstroRide44 AstroRide44 is offline
Re: Wet sanding
what grit paper should u use?
"You can go far with a smile, but you can go farther with a smile and a flamethrower"
Keep it Wingless.....
Old 08-31-2005, 09:14 PM
Re: Wet sanding
If it is for a final finish, I usually start with 1500, which is a little agressive, so you have to be careful. I think give a quick sand with 2000, and then rub it out with compounds.
