Old 08-31-2005, 04:07 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Getting a miss
I notice it mainly at idle. I think i feel it while moving but it could be in my head. I also get the idle going up and down at idle. ICM? What is arching and what causes it? Thanks.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 08-31-2005, 06:04 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Ohh man I hated that when it happend, you probably need a tune up.
Old 09-01-2005, 08:55 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
Re: Getting a miss
1 ignition problem (rot,cap,wires,ignition mod,pick up coil,bad ground, plugs)
2 vacuum leak (o rings, gaskets, hoses)
3 bad CTS switch, some other sensor causing the ECM to react to your idle, MAP
4 low compression on a cylinder
5 internal poblems (lifters, etc)
6 IAC valve or connection
7 other
Connect a vacuum gage to it and see what that does
