Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 08-31-2005, 04:04 PM
longlivetheZ's Avatar
longlivetheZ longlivetheZ is offline
Send a message via AIM to longlivetheZ Send a message via MSN to longlivetheZ
Confused...
I saw a thread kinda about this on here already, but not quite.
Why isn't lowering the compression ratio in order to run boost kinda "robbing peter to pay paul"? Both make power. I think I have some idea of how this works, but I just want to make sure and get a bit more clarity.
Thanks.
Who cares what's in your wallet...what's in your garage?
VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31
Hope you can see the tiny pic...AF reduced the size limit!
Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
Old 08-31-2005, 04:18 PM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Re: Confused...
lowering the compression, then running higher boost doesn't require as highly advanced engine management as if you ran high compression and high boost.
I'd rather run stock compression and mild boost with just an fmu and make similar numbers as the guy who paid for forged low compression pistons and expensive engine management, and still be every bit as realiable.
There is a guy I talked to at one point, who had 9.5:1 compression, 10psi, nitrous, and alcohol injection on an Escort with a ~$300 MS system. It was his daily driver.
Old 08-31-2005, 04:43 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: Confused...
When you cram all that air in the cylinder and the piston wants to keep getting higher and higher but air pressure in the cylinder is pushing back, it can cause some problems. I tried to make that as simple sounding as possible.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 08-31-2005, 07:05 PM
Re: Re: Confused...
I know that. Wasn't really what I was asking. I wanted to know why people would do something like this, as an example: lower the compression from 11:1 down to 8:1 or whatever in order to run 15 psi when they could, for instance, run the stock 11:1 compression and run, say...10 psi...wouldn't the outcome be about the same? All in all...why lower the compression in favor of higher boost pressures? I know the obvious "to prevent detonation" response...I'm looking for the mechanics of it, I guess you could say.
Here's the simplest way I can put it...why is it, or is it at ALL, beneficial to lower the compression ratio in order to run higher boost?
Old 08-31-2005, 07:17 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: Confused...
With high compression ratio pistons, you are filling the combustion chamber with metal to make better use of the existing fuel/air. With low compression ratio pistons, you are filling the combustion chamber with air/fuel then compressing it slighly less. So it makes for more air per cycle in a low compression ratio engine. Hence why you can make more horsepower on pump gas.
Low compression pistons are really good for street driven higher powered cars to allow them to make power on pump gas.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 08-31-2005, 09:44 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
Re: Confused...
if you think of it in terms of cylender pressure, on the one hand you can have high compression with low boost with X cylender pressure. on the other hand you can have lower compression with high boost with the same cylender pressure. both have equal chances of detonating (or preventing it) but one of them has more fuel end air in it and therefore more power (in case you didn't know wich one, it's the low comp high boost one). when you raise the compression you raise the cylender pressure when it's on the compression stroke, this makes a more violent, hotter, and quicker combustion and therefore more power. when you run a turbo or supercharger, you increase the cylender pressure creating a more violent, hotter, and quicker explosion but this time there's more to burn and more power. any time you want to make more power you need to think of 3 things: 1) making the engine and/or the combustion more efficient (lightening it, removing friction, removing rotating mass, higher compression) 2) putting more oxygen into the cylender (by removing restrictions in the intake, nitrous oxide (look it up if you don't know how it works), boost, getting colder air) this way is the easiest and the most common as a first step. and 3) by making the gases exit better (headers, getting a high flow cat or removing it entirely, cat back system, better flowing heads, etc). hope this helps.
Old 09-01-2005, 05:03 PM
Re: Confused...
The last couple posts helped a lot. It's basically what I thought anyway, just added a bit of clarity. Thanks, guys.
