Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-31-2005, 03:56 PM
camry63 camry63 is offline
Transmission
I just got a junkyard transmission installed, and I have 3500 rpms @ 60 mph....something wrong? What should I do?
Old 08-31-2005, 11:29 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Transmission
If the fluid is not fresh, try flushing the transmission.
Sounds like you are not getting into OD. Maybe your OD button isn't connected or not working.
Download the '94 maintenance manual from the sticky at the top of this forum and go through troubleshooting for both the OD button and the transmission shift linkage. Maybe the shift linkage is not adjusted correctly.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-02-2005, 03:20 PM
ProMan ProMan is offline
If the car runs good, the tranny is good mechanically. I would say it's a electronic problem. It can be as simple as a connector not put right, or as bad as TCM.
Old 09-03-2005, 01:16 PM
Orangecrate Orangecrate is offline
Double check any wires that may have inadvertently been damaged when you were tightening up the mounts. There is an overdrive kill switch on my 90 Camry, I presume that there is one on yours as well. Can you verify that it is working correctly?
Kep
Old 09-03-2005, 04:44 PM
Soilent Green Soilent Green is offline
Re: Re: Transmission
My '98 Camry is shifting pretty stiffly, especially the second gear. I'd go through that guide, but do you think most of what's in it will apply to my year cause I'd like details on how to make it shift smoother.
Old 09-03-2005, 06:24 PM
Brian R.'s Avatar
Resident Chemist
Re: Transmission
Some parts will be applicable, but I don't know how much.
First thing I'd try is a flush.
Old 09-04-2005, 07:43 PM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
Everything of note will be. It's the exact same transmission. Some of the controlling components will be a slightly different style, but it will be so muhc the same there won't be a problem.
Ditto on the fact that you're not getting into O/D.
Here's the shifting pattern.
As you can see from the pattern the shift solenoids are hooked up & functioning - so the installation should be OK, less they took the console out.
Probably something wrong with the O/D button. When you depress it the O/D light should come on. When it's pressed in it should be off.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
