Old 08-31-2005, 03:53 PM
jamesmiller66 jamesmiller66 is offline
Thumbs down 2001 pontiac grand prix steering leak
what in the heck is gm thinking designing a power steering system like this on the grand prix. what a hunk of junk. had a power steering leak, couldnt tell where it was coming from, just fluid everywhere, so i replaced the pump, no fixy, so i crank it up on the rack and take a look, no leak while running. so i started turning it. leaked only when it turned right out of the left rack/pinion boot. is this normal for the boot to be filled with fluid, because when i took it out, the right boot had fluid in it.
Old 08-31-2005, 11:03 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2001 pontiac grand prix steering leak
It is not normal to have fluid in the boot. When you get fluid there, it means the rack bulkhead seal is shot. There's one on each side.
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
AF Community Guidelines
