Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 08-31-2005, 01:55 PM
hxgaser hxgaser is offline
slotted vs drilled rotors
I am planning to replace my stock rotor and pads on 01 Civic HX. I am trying to find out what would be the real difference between slotted rotor vs. drilled rotors.
I have noticed that some drilled rotors are not recommended to high performance driving and seems like they are for looks only. But don't race cars use drilled rotors?
Slotted rotors have higher mass and seem to holdup well in high heat operation. But how does the slots, which is designed to clean break pads impact typical break pad life? Is a slotted rotor more durable than a drilled rotor??
Or should I just stick with good'ol vented disks? Any input would be greatly appreciated.
Old 08-31-2005, 02:08 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: slotted vs drilled rotors
When it comes to brakes i feel NEVER EVER EVER EVER cheap out always get the best *while still sane* you can dont' even look at costs remember its all you got to stop you.
While just oem style is pretty good for normal and light spirted drives I race alot and when my motors arn't blowing the fuck up I drive it daily also so i needed something track worthy and ok for street.
I love my Brembo blanks or as you said good ol vented *most everyone will agree hands down best rotor money can buy for a honda* for pads I run HawkHPS hawk claims they sqeek i've yet to find this i had more squeels with oem pads and even then very rare.
As far with race cars they are stopping over and over from 100-200 mph so for them drilled helps for you and I we just lose a bit of stopping area *most supercars/race cars brakes are alot bigger to stop that* Drilled rotors of lower quality do risk cracking.
I know I send a bit of a novel to you but Brembo blanks + Hawk HPS pads you'll be happy with better then stock and price is not much more if not less then hondas OEM.
Old 09-01-2005, 08:55 AM
Black92LudeSI Black92LudeSI is offline
Send a message via AIM to Black92LudeSI
I just bought brembo slotted rotors for my 92 prelude off tirerack. 170 a pair which I dont think is to bad. I'll let you know how they work out.
Old 09-01-2005, 09:13 AM
Re: Re: slotted vs drilled rotors
I definitely agree with you.
I also noticed that Brembo does make both slotted and drilled rotors. I guess they call it their "Sport" series. These rotors area obviously more expensive than the OEM replacement blanks. But the cost is not that outrageous. How you think these would impact break pad life?
You also brought an interesting point. I sure can understand that less surface are means less braking power. So if these sport rotors were as same size as the blank OEM style rotors, would the rotors actually have less braking power than the OEM style blank rotors? I guess that's a question fit for the brake guru.
Thanks for the info.
Old 09-01-2005, 09:26 AM
yes please... Thanks
Old 09-01-2005, 09:36 PM
ok so I had them installed at the shop. The shop said they were warped out of the box, or my hubs are somehow misaligned or crooked. So he told me he couldn't cut them because of them being slotted but somehow he trued them and made them align. They work perfectly now, whatever he did, and I have no shuttering. The breaking power is smooth, I dont know about really strong though, maybe I have to break the pads and rotors in.
Old 09-02-2005, 10:18 AM
... The shop said they were warped out of the box, or my hubs are somehow misaligned or crooked... somehow he trued them and made them align...
What did they do to true them? Were you able to find out?
Old 09-02-2005, 10:54 AM
he told me that he trued the rotors to the hub, because he couldn't cut them. I'll look at my receipt later today and let you know because I think he used some extra part to do this. The breaks are working better today I think, more stopping power, perhaps they had to be broken in. I emailed tirerack, I want them to reimburse me for the extra charges incurred for the warped rotors.
