Old 08-31-2005, 01:39 PM
chigger23 chigger23 is offline
98 Blzaer Water Coming Out Back and Bottom of Tail Pipe and Muffler
I know there will be mostiure with heat, and it is mostly noticed when first turned on.
However shuld water also be coming out of the bottom of the muffler? Or is that most likely condensation from the muffler itself?
Old 08-31-2005, 02:09 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: 98 Blzaer Water Coming Out Back and Bottom of Tail Pipe and Muffler
You may have a series of pinholes rotting their way from the inside of the muffler, out. Condensation under the pressure of exhaust may leak through these pinholes and make the muffler look like it's "sweating" wherever it's lowest points are. Naturally, water will drip from the lowest point it can find. Also check to see that your u-bolts holding your exhaust assembly are torqued on *tight* to ensure a good crimp. If you see water leaking, it's a sure sign that exhaust is leaking. You don't want *any* leaks along the underbelly of the truck, as this could lead to asphixiation. Good luck!
Old 08-31-2005, 02:12 PM
Re: Re: 98 Blzaer Water Coming Out Back and Bottom of Tail Pipe and Muffler
That would be a bad thing.
Old 08-31-2005, 02:38 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
The muffler probably has a drain which is good thing. It allows the trapped water to drain out instead of rotting the inside of the muffler.
Water coming out of the tailpipe is normal.
1995 Factory Blazer Service Manual for sale, PM if interested.
