Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 08-31-2005, 01:10 PM
Indaco Indaco is offline
Send a message via AIM to Indaco Send a message via MSN to Indaco
Exclamation Very Loud Tapping Noise
Yesterday my car (1991 Celica GT - 2.2) began making a tapping sound in the engine. The more i drove the louder it got. It's louder and quicker at higher RPMs. Perfomance wise it drives but has some hesitation, sponginess..loss of power. It stalled once and took a while to get started back up. It sounds like the tapping noise is coming from one of the valves. Anybody here know what the deal is?
Old 08-31-2005, 03:15 PM
91 Celica St 91 Celica St is offline
AF - Advisor
Re: Very Loud Tapping Noise
is it tapping or clanking
wounds like u have a bad valve, prob just needs to be re shimmed
or you could have rod nock, in that case your fucked
Old 09-02-2005, 12:00 AM
Yeah everyone has told me similar - bent valve, broken rod, etc
Old 09-02-2005, 02:31 AM
AF - Advisor
tkae a stethiscope, and listen to various parts of the engine while its running (not too hott it will burn the silicone tubes on the stethicope) if you hear it coming from the head, its a valve, from the bottem of the endging its somthign with the rod
an easyer way to find out is to do a comp test, if its a valve then the compression will be a little lower htan the other cylinders (assuming it was equal before) it wont be lower from rod nock
Old 09-02-2005, 10:06 PM
toyomechanic421 toyomechanic421 is offline
A compression test will only appear lower because of a valve when it is too tight, but since it is making a tapping sound then they must be loose, in which case the compression would stay the same. It sounds like you may just need to adjust your valves. When you do adjust them look for tight valves because as a rule of thumb, a tight valve makes the car run rough, and a loose valve wouldnt be noticable expect for the noise (most of the time). They can be way to loose but that is the rule of thumb with valve train diagnosis. You could have some tight causing it to run badly, and a few loose to make the noise. So the the first step you should do is take off your valve cover and take a feller gauge to your valves, not to adjust them but to see what they are at so you can either condem them as the problem or eliminate them as the problem. The specifications for valve clearence is under the hood.
