Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 08-31-2005, 09:59 AM
lecuenca lecuenca is offline
Send a message via MSN to lecuenca
Automatic transmission kicks up
I have a brand new Dodge Neon 2005 with a 2000 SOHC. It has only 12500 Km and when Iám driving at low speeds it makes a rough change from first to second gear and does a kick very odd.
It does the same when the shift is comming from tird to second.
I dont want to to the dealear wiathout a idea of what is happening.?? banghead:
Any idea...Tanks
Old 09-04-2005, 04:11 PM
yale329 yale329 is offline
Re: Automatic transmission kicks up
I just traded my neon 2002 in, but to be truthful I had constant issues with my four speed auto transmission shifting rough. The dealer replaced the front pump once, also there is a relay by your brake some where that was replaced. Give them hell but be polite. If it is under warrenty, don't stop till you are satisfied.
Good luck Wayne
Old 09-04-2005, 04:42 PM
skatendestroy skatendestroy is offline
Send a message via AIM to skatendestroy
sounds like you need to adjust the bands
and also check your fluid level
Old 09-12-2005, 06:35 PM
ok today i took it to the dealer and told he wood replace the solenoids because they were damage. Do anybody knows wat are they like?
Old 09-16-2005, 01:05 PM
neon_rt's Avatar
neon_rt neon_rt is offline
Skate,
There are no adjustable bands in the 4-speed auto.
Old 09-16-2005, 05:23 PM
You just heard the truth, so help me. Be polite but tell them to fix it. It cold be a front transmission pump problem. do not guve in, please trust what everyone has said,
The best for you, Wayne
