Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 08-31-2005, 06:41 AM
medic6758 medic6758 is offline
Front end problem,,please help
I have a 2000 yukon xl and when I turn the steering wheel all the was in either direction the tires start to squeal,,,does it every time I pull into a spot,,,also the front end feels loose, hit a bump and the front end shook bad almost crashed,,,,,,can anyone help
Old 09-02-2005, 05:59 PM
Denalix5 Denalix5 is offline
Re: Front end problem,,please help
Check your shocks. Your shocks may be shot if you get too much bounce and are not stable when going over bumps.
Old 09-23-2005, 08:49 AM
merci235 merci235 is offline
Mine makes the same tire squealling noise also. I have also noticed that my steering is beginning to feel loose and notice a bouncy feeling over the bumps. It has begun pulling to the right so I am taking it in for a front end alignment. Hopefully this will correct some of this.
The tire squealling has always been there. Probably normal.
