Old 08-31-2005, 02:26 AM
Austin8214's Avatar
Austin8214 Austin8214 is offline
P code P1345
Crank position sensor Cam position sensor corilation error. Has anyone had this problem? If so what was the fix? Truck is a 99 silvy with 143,000 on a 5.7L Vortec. The motor turns over fine there is spark and I have 60psi of fule pressure at the rail. At first a thought it may be the timing chain but it seems like it would at least backfire or something if the timing chain jumpped.
Old 08-31-2005, 05:41 PM
Austin8214's Avatar
Re: P code P1345
anyone?
Old 08-31-2005, 06:05 PM
michelq michelq is offline
Re: P code P1345
i would check dist gear to see if worn out if checked ok i would check timming.check wiring to cam and crank sensors.make sure you put back the dist like you took it off, what i mean mark every thing,good luck
Old 08-31-2005, 06:47 PM
poppajoe poppajoe is offline
Re: P code P1345
http://www.autozone.com/servlet/UiBr...3d8004acf1.jsp
Hope this helps. If this aint it, maybe you can search around on the site a bit.
Old 09-01-2005, 03:24 PM
skipr skipr is offline
I had this code pop up after I changed out the intake manifold gaskets (requires removeing distributor). If its off a tooth the VCM will correct itseft to adapt to the change. Meaning it will run fine but this code will pop up and will not clear untill dist. is put back in proper way. I have a step by step dianostic chart for this code, if you want I could e-mail to you in JPG format.
Old 09-01-2005, 07:07 PM
Austin8214's Avatar
Re: P code P1345
That would be great if you could E-mail it to me. Also i never took the ditributor out it just quit running as i was driving down the road. My E-mail address is [email protected] thanks for your help.
Old 09-01-2005, 11:37 PM
I seemed to have deleted it off my hard drive. I have it in paper copies. I could mail it to you (you should leave your address in my private messages, not here). I have a scanner, but it does not seem to work right. The postage stamp is on me, I think I can afford 37 cents.
Old 09-02-2005, 10:31 AM
99redsilverado's Avatar
99redsilverado 99redsilverado is offline
Re: P code P1345
maybe yall could move this to c/k forum.....
'99 Silverado 4 x 4
bunch of goodies
Old 09-02-2005, 02:08 PM
Re: Re: P code P1345
You hate it when people post earlier years in this forum. Why does this bother you so much? I knew he was in wrong forum, but I don't take it personally.
Old 09-02-2005, 04:45 PM
Austin8214's Avatar
Re: Re: Re: P code P1345
Maybe they need to change the top of the page then. Or you need to read my post where i stated the truck was a 99.
Old 09-02-2005, 05:07 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
The reason people don't like it when others post 98-previous questions and comments is that they are inappropriate in this forum, and many of us don't have clue 1 when it comes to the earlier trucks
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 09-02-2005, 10:22 PM
jethro_3's Avatar
jethro_3 jethro_3 is offline
Re: P code P1345
If this is getting mad what did we do tot hte guy with the Windstar?????? Maybe this guy wants some........ J/K
You will get better information if you use the correct forum is our point. Read the top thread(s) and you will understand..... Not our fault some can't look before jumping off.....
"The Sleeper" '05 6.0L VHO
Cam in and
Low 14's happening at the track
Check out my Ride
Old 09-02-2005, 10:34 PM
Re: P code P1345
Austin8214 does have a 99, tho
Old 09-02-2005, 10:45 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
but he said it is a 5.7 which is the old engine? correct?
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 09-03-2005, 09:46 PM
Re: P code P1345
ding ding ding.....
i am just looking out for the man cause he will get more answers a whole lot quicker from the guys that have the same body style.....
'99 Silverado 4 x 4
bunch of goodies
