Old 08-31-2005, 01:30 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Need Opinions on Starting Problem
My 88 Formula 350 won't start. For a few weeks it was cranking slowly but starting after holding the ignition on for a few seconds (it would slowly speed up the cranking the longer I held it on). So I let it sit for about a week, went to start it up and it cranked once and then nothing. Next obvious thought was the battery is dead, so I gave it a jump, and it cranked fast but wouldn't fire at all. I checked the voltage with the jump on there and it was around 13 volts, idk if that matters or if just the amperage matters when starting. I don't know if it's the starter because the way it would slowly speed up the cranking as I held the ignition, or if it's just a bad battery. Can anyone pinpoint it?
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 09-01-2005, 02:45 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: Need Opinions on Starting Problem
My guess would be the starter, especially if it was previously cranking slowly. Mine does that sometimes, but eventually starts. *knocks on wood*
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 09-01-2005, 04:03 PM
tri-power's Avatar
tri-power tri-power is offline
I'd check the battery and alternator first to see that the voltage is holding steady since it cranked fine with a jump. Remember to charge the battery before you test it. There is a possibility of the starter being bad, but normally those starters do not ehgage when they go bad, but there is always the exception. My guess for starters is a weak battery or a drain in the alternator.Once you rule them out, then you can look elsewhere. Remember if the computer doesn't have enough voltage to operate, the car won't run.
Old 09-03-2005, 10:29 AM
Hmm...well shouldn't it have started up when it was cranking at the right speed? That's the only confusion in my mind, I can understand it not running w/o enough voltage but it should've run as long as I had the cables on there, right?
Old 09-03-2005, 07:06 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Is there any clicking when your attempting to start the car?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 09-03-2005, 08:27 PM
Clicking as in starter solenoid clicking, or some other type of clicking?
Either way, no I don't hear any clicking, just the whirring of the motor turning over.
Old 09-03-2005, 08:34 PM
FormulaLT1's Avatar
Fight the powwa!!!
Did you check the condition and location of the starter gear?. They sometimes become jammed on a chipped/damaged flywheel tooth. Or just become lodged. I would also try a lite tapping on the starter with a hammer.Alot of times if it is a jamming condition that can free up a gear. Good luck to ya.
PS- yes that was in relation to the solenoid.
