Old 08-31-2005, 01:12 AM
lilredcivic lilredcivic is offline
Unhappy my heat sensor or somthings wrong help?
i went to put a zc in my car, things didnt work out. i put my stock motor back in, it runs good, when im driving my heat meter will fulxuate up and down. when i turn off my key and turn it back on it will read normal then start fluxuatiating again. someone help
Old 08-31-2005, 08:52 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: my heat sensor or somthings wrong help?
Hi Noob! Welcome!
If you don't have a Muti-meter I'd try replacing the temperature gauge sending unit. It's cheap and easy to get at (it's the small sensor under the dizzy with a single yellow/green wire attatched).
If you have a meter the resistance cold should be around 142 ohms and should range between 49 and 32 ohms as the car warms up. GL
Old 09-01-2005, 01:45 AM
Talking Re: Re: my heat sensor or somthings wrong help?
thanks worked, about to but a zc motor in my car, will it be fast or what.
Old 09-01-2005, 07:43 AM
johnb16a2's Avatar
Should be quick, the ZC has like 130hp. GL
