axle nut torque spec
I need the spec on the axle nut for a 99 Grand Prix GT 3.8L non-super charged if someone has a manual with this in it I would be gratefull for the number
I am guessing from 150 to 180 anyone? |
Re: axle nut torque spec
It's 151 ft-lbs. ![]() Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec.
if you purchased a new hub bearing, and it has a spec different than Bnaylor posted in the box/instruction sheet, use the spec with the new hub, as changes in bearing design sometimes necessitate a different torque spec for proper bearing pre-load.
Thanks for that spec. The new bearing (national) did not have a torque sheet in it which surprised me. Bearing does look like an exact copy of the factory one.
I just hope the ABS sensor in the other hub held up as I had to impact and pull and hammer to get the stuck CV axle out on that side Thanks again |
Good luck! ![]() Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec.
