Go Back   Automotive Forums Car Chat > GMC > Jimmy
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-30-2005, 10:43 PM
ousooners1baby's Avatar
ousooners1baby ousooners1baby is offline
speedometer lags,abs light on
Takes off in 2nd i think. won't shift into drive.Occasionally on fresh start nothing is wrong till a lil driving.Told it was speed sensor.please tell me how to check wires to and where is it located.On the transfer case?Also read something about a fuse.Vehicle is a 95 jim with 4.3.
Old 08-31-2005, 06:27 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Speed sensor is on the tail shaft. For giggles though, disconnect your battery for a 1/2 hour (simply pull the negative cable) and then hook it back up. See if that at least temporarily cures your problem.
Old 08-31-2005, 03:49 PM
Re: speedometer lags,abs light on
why would i want to temp cure it?seriously though,you think its a computer problem?
Old 08-31-2005, 03:56 PM
rlith's Avatar
Re: Re: speedometer lags,abs light on
We're trying to narrow it down..This is a way to check
Old 08-31-2005, 04:16 PM
Re: Re: Re: speedometer lags,abs light on
will do,right now.
Old 08-31-2005, 08:51 PM
ok.drove it ,ran fine .not sure how to set the memory on motor to idle though.drove it 10 miles.I did drive it last night after it sitting all day and it ran allright.
i let it sit because after my wife told me it done it to her i drove it to work and it wouldn't come out of 2nd gear.i figured it was finally gonna stay like that until i fixed it.whats the correlation between the speedometer and the abs light .all must be tied in together in some switch.any ideas?
Old 09-01-2005, 08:00 PM
next day,drove 100 yds.light came on.No shift.PLEASE correspond!
ok,how do i check the ignition switch,with abs light on can i check fuse box and see if there is 12 v in all fuses.By the way the tranny fuse was fine and the 18 fuse was not installed.Should it be?i believe it was a break fuse.
Old 09-02-2005, 03:30 PM
I appreciate all the tech support.thanks!ok,maybe i wasn't sarcastic enough.Is there any other forums out there that actually give advice.Some would be appreciated.
Old 09-09-2005, 10:27 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Maybe you can kiss our informative asses buddy.
If you want help, be nice, if you want to be an asshole prick then go drive your defective truck to someone who cares.
Threads dead and for god's sake, get some f'n manners moron.
1995 Factory Blazer Service Manual for sale, PM if interested.
Closed Thread
