Old 08-30-2005, 10:08 PM
vladlos's Avatar
vladlos vladlos is offline
Send a message via AIM to vladlos
ride height question
alright.......so 3 weeks ago i got myself some new shocks, tokico hp blues. i'm lowered on arospeed coilovers, i'm lowered all the way in the front and about a half inch from completely lowered in the rear. my ride kinda seems like it got a tad bit bouncier since then and i'm concerned that my shocks are almost dead or something. i have to take inspection in march and that's still pretty far away and i'm thinking of raising my car tomorrow morning but i'm worried that my shocks are shot now. ahhhhhh. i'm freaking out.
what's the lowest i can lower my car with my coilovers without worrying about blowing my shocks. is 3 inches fine? because right now i think i'm lowered like 3.75ish. what about 2.75?
however, even though i'm lowered all the way and whatnot, it doesnt seem as low as derek's 4dr and i can still clear speedbumps without scraping and i don't scrape or bottom out really.
Old 08-30-2005, 10:27 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
well dude i got the same prob.. i have my car slammed and its not giving the suspension any travel which leads the car to bounce.. i thought my tokicos were shot too but its due to having the car slammed too much.. try raising it a little and take it around the block until ur satisfied with the feel. i doubt u blew the blues dude
Old 08-30-2005, 10:33 PM
vladlos's Avatar
Re: ride height question
alright, sweet, because i know that it's bouncy and whatnot and i expected that but when i first got them in and drove around and would hit a bump... my car would just go over it and then drop but now it goes over the same bump and drops and then rebounds one more time slightly.
should i keep it one inch from being completely lowered? cus i'm just gonna measure that inch from the bottom of my coilover sleeve because i'm totally uncertain of how low my car is right now. haha
Old 08-31-2005, 12:26 AM
BullShifter's Avatar
Re: Re: ride height question
Seeing that Tokico's are STOCK LENGTH struts not intended for lowering you can lower about 1.75" without issues. Anyone who tells you differently doesn't know suspension, especially 1PhatCX. Also you need to cut your bump stops in half tp prevent from riding on them which will turn the ride into junk.
Old 08-31-2005, 03:53 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
riding on your bump stops will cause that bumpy ride
Team Lonely Drivers
Old 08-31-2005, 06:24 AM
Hybrid1990crx's Avatar
Re: Re: Re: ride height question
LMAO
But yead Vlad, you gotta raise that bad boy up. Im riding on skunk2 coil overs and I have about 2 inches before the bottom of the colars in the front and about an inch in the rear and im still almost tucking 14s, and the car has some bounce to it but not too bad. And another thing, SLEEVED COIL OVERS SUCK. I dont care what anyone says, i've always said this, and now that I finally own a pair I know for a fact that I hate them, I cant wait to get some regular lowering springs on my car.
Next time you go out to your car look up into the fender whell and look at your control arm, I bet its almost completey up in the fender, which is really bad for your ball joints.
Old 08-31-2005, 06:56 AM
vladlos's Avatar
thanks everybody. i'm gonna go raise my car up a little bit right now.
i already cut my bump stops in half so it's all gravy.
Old 08-31-2005, 08:06 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Vlad, I have the same coil overs and you definitely have to raise them back up. I have mine now set at 10 threads from the bottom all the way around and it's still about a 2" drop. That's almost 2" from all the way down. 12 threads might even be better for ride's sake.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 08-31-2005, 10:08 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
I dont have bumpstops. You could also drop your struts down to help a little. You can drop them down about 2" in front before having axel issues, and more than that in the rear. Then you can raise up your coilovers to compensate.
Old 08-31-2005, 04:48 PM
vladlos's Avatar
what do you mean by dropping my struts down? haha, sorry, i'm still learning all this stuff
Old 08-31-2005, 05:58 PM
Forunn Daberator
If you take the brake line bracket off, and put a new dent in the side of the strut you can lower it down, giving it more travel before it bottoms out. This also lowers your car, so you can raise your coilovers back up some.
Old 08-31-2005, 07:16 PM
so will struts compressed too far.
If you want to "slam" your car spend the $$$$ and do it right. That can be done with true coilovers. You get what you pay for when it comes to suspension.
Hybrid I disagree. I used to think the same until installing Ground Controls on Koni yellows as recommened by CivicSiRacer on many cars. But the way I look at it, GC & Koni yellows cost about the same as an entry level true coilover setup. The key to adjustable right height is the adjustment built INTO the strut not a piece that fits between the spring & spring perch. Another thing, adjustable ride height is worthless unless you use it for what's it designed for and 75% of the people who use don't have a clue.
Old 08-31-2005, 10:46 PM
Jackassi, i was saying that the sleaved coilovers suck for the most part, not true coil overs with threaded shocks.
Old 09-01-2005, 01:56 AM
Right, I agree. I was just saying for sleeves GC's are decent with yellows. The best part about GC's is the Eibach springs can be custom rated per application, no generic spring rates.
Old 09-01-2005, 06:12 AM
Forunn Daberator
By using ride hight correct you mean killing squirls right?
