Originally Posted by 79Formula403
I have a 1979 Firebird Formula with a 403 olds, it has been converted to right hand drive (I live in Australia) But I am wondering about the differneces between suspension of formula and WS6. Is it major suspension parts, or more fine tuning with harder springs/shocks?
Also is there a recommended drum-to-disc conversion for the rear? I'd rather do it right first time.
This is a bit off the point, tho I have wanted to change the hood to Trans-Am type, and have found a functional scoop like that of the 1972 Trans-Ams.. I am wondering what sort of modifications need to be made to the air box to suit.. would a 72 airbox be nesessary or even possible? There was no 403 in 72 so would that therefor mean I'd need a custom job made up?
Cheers guys
the springs were different from model to model.depending on the engine with or without a/c they all had different ratings. sway bars also came in different sizes. your best source to contact for replacement springs as well as info is a company called eaton detroit springs. also to be found on the net. they produce ACCURATE springs for those cars and are recommended by magazines like Hot Rod, Car Craft, etc.Can' t find a better place to get springs from.
Rear discs have been available from the factory for birds since 1979.so you could search for a complete rear axle with rear disc setup. or you can keep your axle housing and get separate items. in that case you need the axles (different length then drum axles), the calipers discs, backing plate and such. there are also conversion kits out.i believe wilwood is one supplier.
as to your scoop question. those were different also, so you might need to modify some...
