Go Back   Automotive Forums Car Chat > BMW > Technical
Old 08-30-2005, 09:45 PM
99onI95's Avatar
99onI95 99onI95 is offline
Airbag light
1996 328ci
My airbag light stays on and I need it to function properly to pass inspection.
I need it to stay on for 6 seconds after ignition and then turn off. If I do not pass inspection then I can no longer drive my car.
It doesn't matter what I have to rig up just as long as it works for the inspection. Please help.
Old 10-13-2005, 12:50 PM
BAVARIANM BAVARIANM is offline
have the problem fixed. It's probabally a seat belt tensioner fault. You start trying to rig the system ,and you could be wearing the drivers side bag for a hat
Old 03-09-2006, 12:42 AM
Tuffdrvr88 Tuffdrvr88 is offline
Send a message via Yahoo to Tuffdrvr88
Re: Airbag light
take it to the dealer, ask them to clear the codes, then drive straight to the inspection, should be ok.
Old 03-09-2006, 12:59 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Airbag light
Clearing the codes won't help if there is an actual problem with the system. Inspection stations can tell if the codes have been cleared recently. Have the codes pulled and start there..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 03-09-2006, 07:53 PM
Re: Airbag light
I was just sayin to do it the same day, that light will eventually come back if not fixed. But usually the Airbag lights are not consistent thrown codes, you may have them cleared and it may onle come back every 3rd or 4th cycle of the key. Just a suggestion though.
Old 03-10-2006, 11:40 AM
Re: Airbag light
Not true. If it's a hard fault, the light will immediately come back on
Old 03-11-2006, 12:27 AM
Re: Airbag light
I know, hence the word "usually".
Old 09-01-2007, 08:56 PM
johnbkendall johnbkendall is offline
Thumbs up Re: Airbag light
clear codes ( it happened to me and I cleared the codes ,it was ok for another 5 months before it showed up again). Replace seat belt latch or entire restraint . good luck codes will tell you which seat .
Old 11-07-2007, 07:22 AM
dugan50's Avatar
dugan50 dugan50 is offline
Authorized Vendor
Re: Airbag light
Since this thread was started over 2 years ago, my guess is that the problem is handled by now. But for those of you reading it, the best practice is to have the codes read by a scan tool (Not Auto Zone...their's won't readi airbag or ABS codes) and then you will know the problem and what to replace or repair. Throwing darts at seat belt pretensioners, clocksprings or wiring under the seat can be costly, time consuming and a wast of money.
I hope this was helpful to you. My information comes from years of experience in these businesses.
http://www.airbagsolutions.com http://www.stolenandrecovered.com
Airbag Service, Airbag Replacement, Airbag Diagnostics
Thank You,
Douglas Gan
Old 11-24-2008, 12:54 AM
ccssit2008 ccssit2008 is offline
Banned
Send a message via MSN to ccssit2008 Send a message via Yahoo to ccssit2008 Send a message via Skype™ to ccssit2008
Re: Airbag light
Originally Posted by 99onI95
1996 328ci
Use BMW Airbag (SRS) Scan/Reset Tool, it will help you.
If need ,pls contact with me: [email protected]
http://www.reliablediag.com
Old 02-02-2009, 03:42 PM
cbmcleaning cbmcleaning is offline
Re: Airbag light
I hit a city bump and my passenger side DOOR HEAD airbag deployed. It was a trip.
Anyway,...HOW can I get the LIGHT to go OFF now...?
2001 BMW 325i
