Old 08-30-2005, 09:34 PM
onet onet is offline
Question eectric window drivers side
i opened my window on my 95 windstar and it wouldnt go back up, fuse is good , relay is calling, the motor is getting the signal but the aparatus isnt working, anyone any ideas, how do i strip it out?angle grinder?
Old 08-31-2005, 06:21 AM
fcrew fcrew is offline
Re: eectric window drivers side
You should be able to unbolt the power window from the track but be careful because it is spring loaded. The best and safest way would be to remove the motor with the armature and secure the "arms" so that when you unbolt the motor it does not unload the spring tension.
Old 08-31-2005, 09:53 PM
cougarman cougarman is offline
To access the bolts holding the motor in place, you have to drill holes through the sheet metal of the door ( behind trim panal ) usually marked by dimples in the sheet metal. Then you can fit a socket through to access the bolts.
Old 09-02-2005, 06:55 AM
netherland24 netherland24 is offline
Send a message via AIM to netherland24
do your lights dimm a tad bit when u try to move it up? can u hear anyhting from the door? cause if it getting a signal and nopttin happens the motor is out. they cost roughly around 80$
Old 09-02-2005, 09:38 PM
dougand3 dougand3 is offline
Check out this thread about 98 windstar power windows...
http://www.automotiveforums.com/vbul...d.php?t=435341
If it is just the motor seized, you can pull it w/o messing with the regulator, taping/supporting the window or drilling a hole to secure a bolt in so the clock spring doesn't bite you.
I did this-cleaned and lubed motor real good. Window worked 5 days, then the plastic gears that the motor inserts into seized up. I now understand why they sell the motor AND gear unit.
I got a motor/gear unit at rockauto.com...DORMAN 742-245....$63.
