Old 08-30-2005, 07:56 PM
mtncat580 mtncat580 is offline
Arrow noisy lifters
Help! I just changed the head gaskets in my '95 grand am, and when i start it up the lifters are making a lot of noise (clicking). I think i may have mixed up the pushrods for the exhaust and intake valves since they're different lengths...does anybody know what order the valves are in for each side of the block???
Thanks in advance!!
Old 08-30-2005, 08:14 PM
mike j hodge mike j hodge is offline
Re: noisy lifters
i have noise in 2000 3.4 grandam motor sounds like timing chain noise. is this possible or lifters.
Old 08-31-2005, 05:23 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: noisy lifters
First of all mtncat580 it would be quite beneficial if you posted the size engine you have since different engines have different specs. Once you do someone should be able to help you.
For Mike j hodge it is possible for the timing chain to make noise. If you have a rapid ticking noise that usually indicates lifters and the noise will either get faster or go away when you rev the engine. Lifter noise is also more prevelant when the engine is cold.
To both of you welcome to AF!
