Go Back   Automotive Forums Car Chat > Buick > Century
Old 08-30-2005, 06:36 PM
ejbcars ejbcars is offline
2001 Buick Century Cruise Control problem
My cruise does not work. The light in the instrument cluster won't light and the cruise control does not engage. I checked the fuse already. Any help is appreciated. Thanks, Ed
Old 11-02-2005, 08:40 AM
mab784 mab784 is offline
Re: 2001 Buick Century Cruise Control problem
I have the same car, same year, and same problem. The reason why mine doesn't work sometimes is because the brake pedal is depressed slightly. And as you know when you have the cruise control on and you hit the brake, it'll turn it off. So, whenever I go to use to my cruise control and it doesn't work, I take my foot and put it behind the brake pedal and I pull it up towards me. That usually turns it on.
Hopefully that helps solve your problem. If that is not the problem then good luck.
