Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 08-30-2005, 06:22 PM
Gil VW Gil VW is offline
Question Busted Hose
I need help identifying a ruptured hose so I can replace it. I'll try my best to describe it.
On top of the engine, next to the intake manifold is a black circular structure which has a couple of hoses attached to it. One of the hoses, the one that faces the front grille, is torn. I need to replace it but I can't find it named or labeled in my Haynes Manual for the car.
I'd be grateful to any one who can help me. Thanks.
Old 08-30-2005, 08:00 PM
boschmann boschmann is offline
Re: Busted Hose
It's part of the crankcase ventillation system. It will only be available from VW, they have exploded views so you can identify it easily.
Old 08-31-2005, 06:44 AM
Re: Re: Busted Hose
Thanks. I've been getting a "gassy" (like gasoline) smell when running the heater or opening the air vent. I noticed that the smell around the tear in the hose smelled the same. Could a new hose solve this problem?
Old 08-31-2005, 07:28 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Yes it should. The intake for the interrior vents is on the passenger side cowl pannel under the wipers. Its problably sucking in the smelly odor from the engine bay.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
