Old 08-30-2005, 03:05 PM
rickyray34 rickyray34 is offline
2000 c-1500 hard start
I have a 2000 c-1500 5.3 litre v-8 with 100000 miles. For the last year, the truck runs and idles fine but it will not start the first time they key is turned over when it is cold. It will start right up and run fine the second or third time you turn it over, and will restart fine if it is shut off for a short while. It seems the hotter the outside temperature the harder it starts. I have an obd2 code reader that does not show any trouble code. I have replaced the evap vent valve, purge valve, charcol canister, fuel filter, spark plugs and wires. It still does the same thing. It has done this for about a year and has not gotten any better or worse. Please help, Thanks.
Old 09-12-2005, 01:34 AM
wade-23 wade-23 is offline
Re: 2000 c-1500 hard start
have you figured out your problem with the hard start, cause i have the same problem with mine
Old 09-12-2005, 06:27 AM
fleettech fleettech is offline
there is a fuel pressure regulator on the side of the intake that goes bad and will cause a hard start condition check fuel pressure
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
Old 09-12-2005, 06:34 PM
I have not figured out the problem yet. Have you found anything out yet? thanks
Old 09-12-2005, 08:09 PM
93mx6lsv6 93mx6lsv6 is offline
My Silverado Z71 5.3 has that exact same problem!!! I have 97,777 miles so that's just about the same as you. I haven't looked into fixing it, just because it usually fires right up after the second or third turn. In addition to the starting sometimes when it does fire up I get white smoke, not blue, just pure white SOMETIMES out of the exhaust. Maybe thats another thing but just letting you know all the things thats going on with mine.
2005 Ford Ranger XLT 4x4 4.0 5spd
-3 in. body lift
-15x8 Mickey Thompson Classic II's
-32x11.50 BFG All Terrains
Old 09-15-2005, 04:57 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
I have the exect same problem as all of you and i know alot of people who do. After replacing the fuel psi. regulator. It helped for a day then after that did it again. It is the fuel pump. On mine when you first start it up the fuel gauge jumps up and down for a little bit. You can get the fuel pump and sending unit to fix both problems. But to fix starting problem it is the fuel pump.
Old 09-15-2005, 05:08 PM
98vert6spd 98vert6spd is offline
yep i had the same problem
i replaced the fp regulatior and the problem went away for a day then came back
got the fuel pump on ebay for 150 shipped brand new
dropped the tank and replaced it
problem gone
