Old 08-30-2005, 02:55 PM
dadof2boyz dadof2boyz is offline
91 Lesabre Harmonic Balancer Replacement
My son is driving my old 91 Lesabre with 220K. Thanks to the posts on this site, I was able to find the knocking problem being the harmonic balancer. By the way, the universal removal tool at AutoZone doesn't work. I had to buy one from CarQuest ($40) because it uses special bolts. My question is this: Will the harmonic balancer from a 93 Pontiac Bonneville with a 3800 work as long as I get the Crankshaft position sensor as well? In looking at them, the timing bands on the 93 are further apart than my existing one so I will have to have the sensor. However, after installing it and driving it for about 20 miles, now it won't crank. I noticed that it was losing power and acceleration before getting to this point.
Old 08-31-2005, 07:34 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 91 Lesabre Harmonic Balancer Replacement
Do you have any codes?
Old 09-01-2005, 07:00 AM
The Service Engine light never came on. I haven't coded it since it quit running as I don't have a decoder.
Old 09-01-2005, 10:04 AM
imidazol97 imidazol97 is offline
AF -Advisor
Use a wire with a fuse in it (or a paper clip) to cross terminals A and B under the dash on the ASDL connector. Have the key on (engine NOT running). Should get 12s 3 times then codes followed by 12s again.
