Old 08-30-2005, 01:00 PM
Fredrick_NP's Avatar
Fredrick_NP Fredrick_NP is offline
DOHC better then SOHC?
Someone was telling me that the dual cams have more power but SOHC have less to break so they are more reliable. Is that true? Does it really make that much of a difference?
Im looking at a 2001 Dodge Stratus coupe with a Mitsubishi 3.0L SOHC, and a 2004 Stratus with a Chrysler 2.7L DOHC. They both have the same HP, but I wonder how reliable the engines are.
I would rather have the american engine, but the older 2.7L seemed to have some problem... (although people say the newer ones fixed the problems) and being DOHC, wouldnt that make it even more likely to break?
Old 08-30-2005, 08:22 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: DOHC better then SOHC?
Neither of those 2 engines are exactly brilliant, but the 2.7 definitely has problems.
Surprisingly enough, the Chrysler 3.2 and 3.5 liter V6 engines are DOHC and are very reliable.
Generally speaking DOHC engines produce a bit more power and are more expensive to manufacture and repair.
But as far as reliability goes, this is more dependent on the design and the use and maitenance its seen than on basic valvetrain layout.
Old 08-30-2005, 10:53 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
dohc has the potential to provide with better top end power and sohc with better low end torque, it's not a huge difference on a street car but if you're building a racecar it is a big enough deal.
Old 08-31-2005, 05:51 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
Re: Re: DOHC better then SOHC?
Wrong, explain yourself.
Old 08-31-2005, 05:59 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
go search Honda VTEC engines and you'll find that both engines are reliable, but the DOHC will beat a SOHC up and down all day long!
A SOHC D16Y8 is the stock Civic Vtec engine, but the EM1 (Si) DOHC B16A2 has the same displacement and is also a Vtec engine...it gets better gas mileage, has more power and is just as reliable as the SOHC.
I have a 99 GSR w/ a B18C DOHC VTEC engine and i've had a D16Y8 Civic, but i don't think that i'd ever go back...I get more gas mileage, have more power and a lot more possibility for power than the Civic. My opinion is that DOHC engines are much better than SOHC!
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 08-31-2005, 08:22 PM
Reed Reed is offline
Send a message via AIM to Reed
in general sohc engine have less moving parts so less moving parts at low end provides better torque, dohc engine have more flow potential therefore they have more power at top end. in general
Cars are like music.
If it ain't fast it ain't shit.
Old 08-31-2005, 09:08 PM
MagicRat's Avatar
Re: Re: Re: DOHC better then SOHC?
with respect, beef burrito is on the right track here.
Most DOHC engines are 4 valve per cylinder.
Most SOHYC engines are 2 valve.
Compared to a SOHC engine, a DOHC 4 valve engine has lower valve train mass per valvespring and can rev higher. The larger port area is better suited to high rpm use. Engine designers can and often do get maximum benefit from these traits by allowing camshaft profiles with more lift and duration that favours maximum volumetric efficiency at high rpm, over the SOHC design.
Of course, this does not apply to all DOHC engines, because the engineers may have different design parameters for certain engines and may not choose to tune a DOHC engine this way.
Old 08-31-2005, 09:28 PM
thank you for responding for me, i was going to say something like that but didn't have time to post it first.
Old 09-01-2005, 11:17 PM
ec437's Avatar
ec437 ec437 is offline
This isn't exactly relevant to the question, but I just though I'd brag a little bit: I used to have a QOHC engine
SoStAsSaId: and the flight attendant is cute... if i was a lesbian, i'd join the mile high club
<---call this number
Old 09-02-2005, 12:11 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
you had 4 camshafts per bank of cylinders?
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 09-02-2005, 12:18 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
You can't say that one is more reliable than the other. There are SOHC engines that have 4 valves per cylinder. You're better off with DOHC for performance in my opinion. It is simple, airflow equals power and DOHC engines have more airflow. Ah, but I just said that there are SOHC engines with 4 valves per cylinder, why not just get one of those?
Two words, valve overlap. Want to tune your engine? You can tune the valve overlap much better and easier in a DOHC engine.
If you're concerned about reliability there are other things you need to be looking at.
