Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-30-2005, 10:09 AM
dnl_em dnl_em is offline
ABS Sensor Testing
Is there a way to test the ABS Sensors on a 2001 Rodeo, 2.2L engine?
I get an intermittent ABS light. I have inspected the brakes, fluid, and wiring, and it all looks good.
Old 09-01-2005, 10:36 AM
wb4lbg wb4lbg is offline
Try looking here.
ABS DTC
Also, if you can get to the connectors and stick an ohm meter on them, these are the correct readings for the three sensors.
FL/FR 2.0-2.8 kOhm
Rear 1.0-1.7 kOhm
Could also be bad wiring or a bad connector.
Hope this helps. Good luck!
JWS
'99 Rodeo LSE 4WD
'00 Escort ZX2
'00 Olds Silhouette
Old 09-01-2005, 11:06 AM
Thanks for the information.
