Old 08-30-2005, 04:39 AM
BaXuyen BaXuyen is offline
Send a message via AIM to BaXuyen Send a message via Yahoo to BaXuyen
91 Turbo Engine into 96 RS?
Hi, I need some help and advice as what i should do.
I'm thinking about getting a 96 Eclipse RS, and swapping the engine from my 91 turbo Talon into it.
The reason is because my 91 Talon is in pretty bad shape visually, the engine in this car is only 70k, but the interior and exterior isn't too pleasant.
The eclipse that I wil be purchasing is only $$600-1k, magna flow exhaust, the engine is only about 101K, the transmission is sitting in two seperate box. The interior is pretty good. A little tear on the driver front seat, a missing bottom panel from the center console, the plastic piece that cover the passenger air bag is warp from sitting in the heat too long(can be replace at local junk yard for cheap), light damage on the passenger front quarter panel(local junk yard too), a little hood damage and rust, need to be repaint.
So if i get the Eclipse RS will the tranny from my 91 Talon work in the RS. I want to use the gear box that come with the RS because the one in my Talon isn't shifting too smooth. My Budget for this is $$1-2k. I can get a mechanic to pull the engine and tranny from the Talon and put it in The RS for about $500. Repaint and bodykit will come later, I would keep the turbo stock(for now)
I also would like to know. What other part in my Talon can be salvage for the Eclipse in the future, since Mitsubishi are notorious for bad tranny?
I will update with pics of the RS later.
Old 08-30-2005, 08:34 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: 91 Turbo Engine into 96 RS?
That driveline will not bolt into a 2g NT, not without quadrupling your budget
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-31-2005, 12:33 AM
Re: Re: 91 Turbo Engine into 96 RS?
After reading the archive, it seem that it's not as easy as i had hope it would be.
Thank you for your feed back. Need to rethink alot before i totally commited myself to this project.
Old 08-31-2005, 01:10 PM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
If your unhappy with the looks of your 91...just put your money into the body and swapp out the interior. Easier and cheaper solution.
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
Old 08-31-2005, 01:30 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
you could find a turbo for the 91 turbo for 2 grand easy. I see them all the time
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
Old 08-31-2005, 02:36 PM
MexRocket's Avatar
MexRocket MexRocket is offline
i say just repaint your 91 talon.. they looks sweet one color... you could get the interior for the talon with all the carpet and stuff for under 200 bucks i think... i have a good link, i get to you after my stupid class that im in right now....
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
