Old 05-07-2002, 03:09 PM
mhpspeed mhpspeed is offline
Send a message via AIM to mhpspeed
gluing resin
dose anybody else have truoble glueoing resin to plastic or resin to resin? It takes my testors glue about a day and a half days to dry is this normal?
Old 05-07-2002, 04:19 PM
patate's Avatar
patate patate is offline
yes because it is not for this kind of plastic you have to use epoxy or super glue for a good gluing and a good time of drying
Old 05-08-2002, 12:54 AM
wkma7six wkma7six is offline
Mhpspeed, you need CA or "superglue". Its better when you buy CA from hobby shops instead of Krazyglue or Superglue. It is essentially the same stuff (CyanoAcrylate), but in the times that I have used these two types, the CA works much better. The "superglue" stuff seems to be more brittle and cracks much easier. There is also an activator or sometimes called "a kicker" for CA that allows it to cure even faster. The regular model cement is only for styrene to styrene joints and melts them together to form a bond. Hope this helps. - Walter
Old 05-08-2002, 05:29 AM
flyonthewall's Avatar
Car Mod guy
Yep, superglue or epoxy is all u can use for resin. An epoxy adhesive is perhaps the best option as it will give u a little time to reposition the piece to get it right.
Old 05-08-2002, 02:43 PM
alright thanks i havent tried supewr glue buit i did try hot glue but it didnt work cause it dried to fast and then it would just break off plus it left a whole bunch of glue strings that were a pain to get off. bdut thanks i think i am gonna get some of that ca stuff
Duplicate Resin parts Casting Kit suggestions? smileygirlmel86 Car Modeling 9 12-09-2010 08:59 AM
Resin and more Resin MidMazar Car Modeling 2 09-08-2005 12:57 PM
Gluing Resin to Plastic ? Hiroboy Car Modeling 3 12-01-2002 06:40 PM
stripping resin (i looked in FAQ, nothing on resin stripping) tony350ss Car Modeling 1 11-29-2002 07:22 PM
How many hours a day to you spend glued to the computer monitor? kris COMPLETELY off-topic 7 08-01-2001 06:08 PM
