Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 08-29-2005, 11:17 PM
bigez bigez is offline
no crank no start
i was wondering if anyone had a problem getting their starter to work i replaced it last year and it worked fine til sunday i assumed that was the problem again so i replaced it and it still wont even turn over my battery cables seem fine any suggestion
Please help,
Eric
Old 08-30-2005, 03:39 AM
yale329 yale329 is offline
Re: no crank no start
conections, and more conections. If you can clean them. Check the battery and any wires going to the starter. Try starting in neutral. I will look up all yhe causes I can find .
Question?? Does your horn work, your lights, signals etc. Please post relpies. Good luck Wayne
Old 08-30-2005, 07:35 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Did you check the relay? Do the horn/starter relay swap test and see what happens. Put your starter relay in the horn spot and see if your horn honks. If it does then, your relay is good. After that you will have to find a loose/bad connection somewhere. Make sure you don't have any corrosion on the terminals or on the wires themselves. The wires will get corroded down underneath the battery tray on occasion.
Old 08-30-2005, 09:21 AM
Re: Re: no crank no start
Exellent advise. Now how about helping me with my clatter
Wayne
Old 08-30-2005, 01:56 PM
Fractured1 Fractured1 is offline
and dont rule out the safety neutral switch or connection
Old 08-30-2005, 03:05 PM
thank you all i did the relay swap and it does not start in neutral everything else electrical seems to be working fine if you think of anything else please let me know and thanks again for all the imput
Old 08-30-2005, 04:50 PM
Just because it doen't start in neutral doen't rule out the safety neutral switch, there is a specific test for the switch in the tranny
Old 08-31-2005, 08:15 AM
OK, when you put your key in the ignition what happens? Do you get lights and the usual chimes? When you go to start the car, what happens? Nothing at all, clicking, does the starter kick in but not turn over? Some more info please.
Old 10-18-2005, 10:49 AM
AUTOUSA's Avatar
AUTOUSA AUTOUSA is offline
mine is 5-speed stick.I have same problem.Everything works in vehicle etc,but when i try to crank it nothing happens,no noises of any kind..Help.
