Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-29-2005, 10:15 PM
gerob2 gerob2 is offline
will not shift from park
97 blazer console shift is stuck in park. Car starts fine but will not come out of park. I assume there is a switch on the brake but couldn't find it in the dark.
Old 08-29-2005, 10:38 PM
cedarjames cedarjames is offline
ignition
your ignition isnt turning all the way off, check page 7 or 8 I am having similar probs but have tride some repairs and am looking for more ans, please forward any info you get thanks. yours is prob an ingnition prob,
Old 08-29-2005, 10:40 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: will not shift from park
ignition switch is bad or the brake switch is not releasing the tranny lock.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-30-2005, 11:20 AM
Brian_D Brian_D is offline
Had the same trouble on my '97.
To bypass the BTSI solenoid:
1. Lift the leather boot around the shift lever where it "snaps" into the console.
2. On the right-side (passenger side) of the shift lever, find the white tab and carefully depress the tab and shift out of Park and into Neutral.
As to the problem:
Is the only symptom the inability to shift from Park?
From Park, can the ignition be placed from on/run to off and the key removed?
Does the truck experience intermittent hard starts (ignition in Start or Run but no dash lights) or dies intermittently?
My 'no shift from park' problem was caused by a dirty electrical connection at the neutral safety switch(?) mounted on the left-side (driver side) of the transmission.
Old 10-18-2006, 07:10 PM
sebryce sebryce is offline
I am having the same problem; however, I can't get the key out as it only turns off 1/4 turn... Stuck in park... HELP? I have replaced the battery, ignition (key part) and silenoid behind the key
Old 10-18-2006, 07:22 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
this thread is more than a year old. you may start a new thread if you like. please refrain from posting in old threads in the future.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Closed Thread
