I purchased a 98 Venture that runs great, but the service engine light and air bag lights are on all the time. I purchased an OBD2 code reader, but can't get a signal at the diagnostic terminal. I've tried the code reader on other GM products and it works fine. Where do I start looking for the problem?
check your fuses on the right hand passenger side panel, you will find a 10a fuse running cigar/DCL(diagnostic link conector) hope this is the fix to your problem
Thanks for the tip. The fuse was burned out because the cigar lighter was shorted. Code reader now gets a signal. The code reader came up with two generic codes, cylinder 4 misfire detected and catalyst system efficiency below threshold (Bank 1)
If anyone knows anything about these, I will be glad for any info. Meanwhile I will search the internet. |
Re: No signal at diagnostic terminal
I just replaced the secondary O2 sensor after getting codes PO 140, 300, 401.(same as or similar to your readings) after driving the car a few times, the light went out.
Fix the misfire problem you may loose the cat efficiency code.
Re: Re: No signal at diagnostic terminal
Probally not..if this code is displayed, the converter needs to be replaced. But the misfire needs to be corrected, because a misfire will kill a converter
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
Re: Re: Re: No signal at diagnostic terminal
I cleared the codes and the only one that came back was P0420.
My next step will be to test the O2 sensor after the coverter. I imagine the catalytic converter is kinda pricey. Thanks for the help. |
Re: Re: Re: Re: No signal at diagnostic terminal
Vinyl adds horsepower, right? |
