Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 08-29-2005, 09:15 PM
ramitall ramitall is offline
Exclamation electrical snafu...radio,dome lights,pwr mirror
Odd problem...1999 ram 3500 maxi
did a jumpstart a few days ago...(i know) now I have no power to the dome lights, power mirrors or the "constant" power to the radio.
I have checked all of the fuses and relays I can find... they all check out
I have also done continuity tests on all of the systems wire by dog gone wire from the end connections to the fuse panel to the main power block under the hood.
HELP!!!
Old 09-04-2005, 01:42 AM
89ltd 89ltd is offline
Re: electrical snafu...radio,dome lights,pwr mirror
check for power at the fuses with the iginition on for the dome, radio, mirrors, if there is no power at the fuse, you will have to trace it farther, maybe no power from the ignition switch to the fuse block.
Old 04-08-2006, 07:29 PM
kirk144 kirk144 is offline
did you ever find out what this problem was ? since im getting the exact same thing on my 98 dodge ram rv van
Old 01-23-2007, 05:54 AM
nbaker87 nbaker87 is offline
my 2000 dodge ram pickup is doing the same thing since it has ben jump started any clue what it could be yet?
Old 01-23-2007, 08:40 AM
alloro alloro is offline
Did you check and see if the fusible links are still good?
Old 06-18-2007, 12:08 PM
jm897 jm897 is offline
my truck just did this the other day. (2002 Ram 2500) in the fuse panel in the cab there is a fuse labeled I.O.D. fuse #12 on my truck. It has a black lock around it you have to pull that out but it wont come out all the way, then you can open the end of the lock to remove the fuse. That fuse was blown on my truck. I replaced it, interior lights mirrors and radio all work now. hope this helps
