Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-29-2005, 07:27 PM
dghedrick dghedrick is offline
2000 Rodeo 4x4 - slipping out of gear
Just started yesterday. Worse in the lower gears. Feels like it pops out of gear, revs high, and then pops back in. Seems to run much smoother at higher speeds but maybe still some hesitation. Question? Could just simply being a quart low on oil cause this?
I've researched the forum and understand that a tranny flush would be the first thing to do... maybe followed by a possible shift solenoid problem or a worn valve body?
Rodeo has 79K with no problems for the last two years. I change the oil every 3-5K and have noticed more oil consumption, but never had the tranny slipping problem.
Thanks in advance for advice! DGH
Old 08-29-2005, 07:32 PM
rodeo02 rodeo02 is offline
Do a search for 'range' or 'mode' sensor. This is the most common cause for 4L30E AT issues.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 08-29-2005, 07:50 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 2000 Rodeo 4x4 - slipping out of gear
also, when was the last time you had the tranny fluid changed?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
