Go Back   Automotive Forums Car Chat > Honda > Integra
Old 08-29-2005, 03:57 PM
adrenalin2si adrenalin2si is offline
Send a message via AIM to adrenalin2si
Water is bad for your block
well last night i got stuck in a bad storm hit a flooded road and well cold air intake isnt a good thing to have then. anyway blew a rob through the front of my block so now i need ideas any good ideas of what to do obviously need a new block gotta check the head see if its ok but LS block vtec head? motor swap 2000 acura integra with 41k on it lots of parts to use on a new but need some ideas of whats a good route to go here rebuild or upgrade?
Old 08-29-2005, 05:58 PM
ur2slow4mytypeR ur2slow4mytypeR is offline
Re: Water is bad for your block
LS vtech is a nice engine but since u blew it i recomend to rebuild another one. its gonna be pretty hard but you can do it.when i got my gsr i blew the engine the same way so i went to a JDM type R(b18C) and my friend just built a LS vtech turbo in a 2weeks. so good luck
Old 08-29-2005, 07:40 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
oo well first its LS VTEC...so are you saying you had hydrolock? If so that motor is done...
Old 08-29-2005, 08:26 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Well since he said he threw a rod through the block, then yes that engine is done.
I say just do a GS-R swap since you have to buy a new block anyways. Might as well since you don't have a block to work with anyways.
Old 08-29-2005, 09:51 PM
97integrals's Avatar
97integrals 97integrals is offline
Re: Re: Water is bad for your block
I would have to second that idea!!
Old 08-30-2005, 12:15 PM
Well..
well a new engine is a good idea but since this couldnt have happened at a worse time. im stuck with alittle more cost effective solution. ripping the head off today to check the valves and make sure it will run fine going to go ls vtec since i can get a block with pistons rods and crank for 200-400$ im curious though i know people who have done this but what are the benefits i understand its better to turbo this motor will i have less power then a gsr? and what modifications am i looking at or if anyone knows a site i can find a list of modz please let me know
