Old 08-29-2005, 03:53 PM
Joshta's Avatar
Joshta Joshta is offline
bought a 460
i purchased a 460 out of 75 lincoln continental for $150 about a month ago. its in my garage on a motor stand completely stripped. i lucked up and it has very little internal wear. i plan on building it and eventually putting it into something as a street car. i would like to mat it to a 4-speed and use somewhat normal tires if possible. here's my thoughts so far:
block balanced and blueprinted
bored; little or lot, (nice bore spacing)
heads ported and polished
forged pistons (flat,domed?)
semi-wild cam
intake to match
1.7 rockers
about an 850 carb
LT headers
electric water pump
no a/c
i don't know about the ignition and realize cooling will be a problem. My question is if any of you know any good sites or books on buildups like this. i have no idea about the #'s i'll need for the heads, cam, headers, compression, ect. to get em to work together properly. i should be talking to my machine-man soon so i'll know what size over will be needed in the rebuild kit. any help is appreciated.
Old 08-29-2005, 04:21 PM
Rod&Custom's Avatar
Rod&Custom Rod&Custom is offline
Send a message via Yahoo to Rod&Custom
Word of advice: Never machine and build your motor before your car is ready. You will end up redoing most of it if it sits for any length of time. Also, and 850 carb sounds like overkill to me. I am sure a 750 would be PLENTY on that fairly mild N/A build.
Old 08-29-2005, 05:04 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: bought a 460
Agree 100%
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 08-29-2005, 05:30 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: bought a 460
1969 Cougar
357w & TKO - 475hp
Old 08-30-2005, 07:13 PM
Joshta's Avatar
good idea; sites anyone?
Old 08-30-2005, 08:32 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: bought a 460
One more thing, if you must use a manual trans, machine the rear of the crank to accept the correct clutch pilot bushing. Have the man\chine shop do this when the crank is out.
This is necessary for a manual set up, but it still allows you to use an auto trans in the future,
Old 08-30-2005, 08:34 PM
MagicRat's Avatar
Re: bought a 460
One more thing, if you must use a manual trans, machine the rear of the crank to accept the correct clutch pilot bushing. Have the machine shop do this when the crank is out.
Old 09-02-2005, 01:45 PM
Mines69Olds's Avatar
Mines69Olds Mines69Olds is offline
Send a message via AIM to Mines69Olds
Re: Re: bought a 460
Do you know around how much that would cost?
