Old 08-29-2005, 03:37 PM
MommaFay MommaFay is offline
Question I need help with 90' civic wiring problem!
I just bought a 1990 Honda Civic Hatchback, and have been pulled over twice so far for my tail lights being out. I've replaced ALL the bulbs and fuses! Still...nothing. :-( I can't afford to take it into a shop because they charge of the rear and I just put all my money into buying the flippin thing, what do I do?
If anybody can give me a run threw on where to start so that I could fix it myself I would SOOOOOOOOOOOOOOOOo appreciate it. Really.
Old 08-29-2005, 05:19 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: I need help with 90' civic wiring problem!
if you recently added an aftermarket deck, sometimes the wires will short against the metal back there causing them to blow the fuse (radio and tails are on same fuse) id check that first.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-30-2005, 09:36 AM
Shouldn't be deck.
The deck was proffessionally installed. Last night I took the dash apart and wiggled the wires around the stearing wheel...it made the lights work...probably not for good, but atleast I know where the short is right?
Old 08-30-2005, 02:12 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
looks like you got a loose wire. now go find it and fix it. its the switch on the drivers side of the steering wheel
Team Lonely Drivers
