Old 08-29-2005, 01:16 PM
catfishnfool catfishnfool is offline
Question q's about wiring 1 ohm
I have 3 JL 12'' W3's and a 1000d memphis 1 channel, i need to know how to wire the three subs down to 1 ohm with the amp (only 1 channel), if you can help please email me. [email protected]
Old 08-29-2005, 01:17 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: q's about wiring 1 ohm
what impedance model are the subs
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 08-29-2005, 01:20 PM
they are dual 6ohm voice coil 300watts rms
Old 08-29-2005, 03:49 PM
sr20de4evr's Avatar
then wire everything in parallel, that will net you a single 1ohm load
'01 Black Sentra SE
'05 Silver WRX STi
Old 08-29-2005, 04:30 PM
Re: Re: q's about wiring 1 ohm
how do i wire them parallel ? I do not know how to do so.
Old 08-29-2005, 04:49 PM
sr20de4evr's Avatar
attach all 6 +'s to the amp's + and attach all 6 -'s to the amp's -
'01 Black Sentra SE
'05 Silver WRX STi
Old 08-29-2005, 04:59 PM
Re: Re: Re: q's about wiring 1 ohm
6 +'s and 6 -'s?? i have three speakers where are the 6 at? isn't there three of each neg. and pos.?
Old 08-29-2005, 05:03 PM
sr20de4evr's Avatar
They're dual voice coil subs, which means each sub has 2 coils, so 2 + and 2 - per sub.
'01 Black Sentra SE
'05 Silver WRX STi
Old 08-29-2005, 05:08 PM
Re: Re: Re: Re: q's about wiring 1 ohm
i see, so take the 6 neg wire them together, then take the 6 pos. wire them together, then put only 1 1/0 gauge wire into the pos. and neg. of the amp?
Old 08-29-2005, 05:14 PM
sr20de4evr's Avatar
uh, 0awg will be WAY too big, you'll need something more like 12-14awg. And you can just daisy chain the wire from terminal to terminal, so go from the amp's + to the first speakers +, then to the other coil's +, then to the next speaker's +, etc, until you get all of them. Then do the same thing on the -.
'01 Black Sentra SE
'05 Silver WRX STi
Old 08-29-2005, 05:16 PM
Re: Re: Re: Re: Re: q's about wiring 1 ohm
with seperate peices of speaker wire? or the same piece of wire connected to all the voice coils?
Old 08-29-2005, 05:18 PM
sr20de4evr's Avatar
doesn't matter, it would probably be easier with seperate pieces though
'01 Black Sentra SE
'05 Silver WRX STi
Old 08-29-2005, 05:20 PM
i am not going to lose power running through all those different wires? do you think that i will need a cap or extra batt. for these 1100 watts?
Old 08-29-2005, 05:25 PM
sr20de4evr's Avatar
As long as you get a good connection with each of the wires then you won't lose any more power than you would with one long one
A cap won't be necessary as long as you set the amp's gain properly, if you don't set it properly then you could have problems, but if that were the case you would have problems with a cap also, so either way a cap isn't needed.
'01 Black Sentra SE
'05 Silver WRX STi
Old 08-29-2005, 05:26 PM
sr20de4evr's Avatar
another way you could wire them is like this:
same result, in fact it's the same wiring scheme, you're just going about it a little differently
'01 Black Sentra SE
'05 Silver WRX STi
