Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-29-2005, 12:20 PM
JDOK JDOK is offline
power door locks
I have a 1999 Silhouette with a door lock problem. The drivers side door lock paddle switch will lock the doors but not unlock the doors? The locking mechanism on the drivers door (plus all others) works fine using all of the other switches and the keyless. I have replaced the switch but with the same results. Anyone have any ideas?
Old 09-04-2005, 07:48 PM
cdru's Avatar
cdru cdru is offline
Re: power door locks
Broken wire?
Vinyl adds horsepower, right?
Old 09-08-2005, 10:52 AM
Thanks for responding. I attempted to find a wiring problem but was unable to find anything. I suspect there is a broken wire within the insulation that is not apparent. I was also wondering if the security sysem may be causing an issue? It's doughtful but who knows. In any case if anyone knows which wires to look for (color code) it would be appreciated if you would pass it on to me. Thanks!
Old 03-16-2006, 10:57 AM
Flyer88 Flyer88 is offline
I have almost exactly the same problem except the switches will only unlock the doors, not lock them. All other related locking functions work correctly. The dealer told me it must be a wiring issue, probably around a 3-way connection, maybe located under the passenger seat or behind the kick panel in the passenger footwell. I haven't looked for it yet. Please post a reply if you find the solution, and good luck.
Old 08-02-2006, 10:58 PM
klhenrichs klhenrichs is offline
I have the same problem as the original post - will not unlock - I have tried replacing the switch - it is not the switch. Still trying to locate the wires.
Old 08-04-2006, 07:43 AM
I have since noticed that I cannot lock the doors using the key in the driver's door, although I can still lock them using the key in the tailgate or the passenger's door. This isn't new and I believe it is connected to the same problem, I just didn't notice it before.
Old 08-04-2006, 10:13 AM
GregA's Avatar
GregA GregA is offline
Probably a wiring issue to the driver side switches.
I have some information & wiring diagrams HERE, a few lines down the page. Look for the links having to do with the lock system & switches.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 12-07-2006, 01:12 PM
bbkinsman bbkinsman is offline
2002 Olds Silhouette - Driver & passenger door locks won't lock or unlock with switch, but when you start the car and put in gear all doors lock. Switches still don't work but when you shut the car off all doors unlock. Keyless remote works both to lock and unlock. I took door switches off and tested and they seem to be working ok. Any ideas or suggestions
Old 12-07-2006, 09:32 PM
GregA's Avatar
Sounds like you have a broken wire or loose connection between the switches and Body Control Module (BCM).
Take a look at the following page for a diagram that might help. The BCM is on the passenger side kick panel. Removing the insulator will allow you to see it. I have pictures of where it is on the site.
Door Lock Switches
Take Care,
Greg A.
Old 03-07-2008, 07:54 PM
rmellnick rmellnick is offline
I have a 2003 Silhouette with the same issue. Doors unlock with everything except the unlock switch on each door. I think it is a broken wire or bad connection.
My question is the voltage at the switch should it be 12volts ? Power should be on the white wire.
Could it be a Body control module?
Thanks in advance
Russ
Old 03-15-2008, 01:11 PM
cortster cortster is offline
Thumbs up Re: power door locks
I had the same exact problem and I just recently resolved it. Underneath the carpet on the passenger side there is a wiring harness that is susceptible to corrosion. Removing the seat might help. Look for wires showing green corrosion. I repaired alot of them even some that I suspected that were still working but I thought would go bad soon, so I cannot be specific as to which wires to repair. The areas that you are looking for are the areas where they were split by the factory (wrapped with a black clothy tape).
Old 03-15-2008, 03:15 PM
That is exactly what it was. I found the splice for the door unlock circuit and fixed it.
Worked like a charm. Thanks to everyones help saved me some $$$$$$
Russ
Old 03-15-2008, 03:56 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Glad to see the issue has been resolved. If you look through some of the threads in the Venture, Montana and Silhouette forums you can see that this is a common issue.
I'm closing this thread to further posts as it is an old thread that has been resurrected.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Closed Thread
