Old 08-29-2005, 12:12 PM
ttoommssmmiitthh ttoommssmmiitthh is offline
Send a message via AIM to ttoommssmmiitthh
Transmissoin Fluid... wheres the bolt?...95
Wheres the bolt, screw or whatever you wanna call it under the car located to change your transmission fluid on a 95 grand prix. Also is there any special way you shoudl change your transmission fluid on a 95 grand prix? Just curious... Thanks
Old 08-29-2005, 06:07 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Transmissoin Fluid... wheres the bolt?...95
If you have an automatic you will need to drop the transmission pan to change the fluid and filter in the transmission. There is no one bolt or drain plug to change the fluid in the transmission unless someone installed one.
Old 08-29-2005, 08:51 PM
diezelman's Avatar
diezelman diezelman is offline
Send a message via Yahoo to diezelman
your car isn't a 97-2000, but this link (posted by Big L) gives you a good idea of what you have to do, as far as removing the whole pan, gasket, and filter. Hope it helps.
http://www.grandprix.net/upgrades/tranfluid.html
JP
