Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 08-29-2005, 11:01 AM
felixjosegacosta felixjosegacosta is offline
error code how to?
Hi,
I need to know how can i get de error code my rodeo has the check engine light on. help me
Old 08-29-2005, 11:46 AM
wb4lbg wb4lbg is offline
First thing, go out and take your gas cap off and put it back on, be sure it clicks three or four times. You wouldn't believe the number of CEL's that are generated by a loose gas cap.
If that doesn't make the light go out, take your truck to the nearest Autozone. They will read your code for free. If they don't know what the code means, post back here and someone can look it up for you.
Hope this helps! Good Luck!
JWS
'99 Rodeo LSE 4WD
'00 Escort ZX2
'00 Olds Silhouette
Old 08-29-2005, 12:27 PM
nightguy1 nightguy1 is offline
codes
dpending on year use a paperclip to jump the two closest prongs on the assembly line data link,a 12 pin terminal located on the drivers side under dash on my 92 rodeoon the right side od 12 pin link and turn key to accessories ,Not all the way on,you should get check engine light to flash codes.refer to haynes manual for troubleshooting.
