Old 08-29-2005, 09:40 AM
nexdrmec nexdrmec is offline
Question Brake bleeding
i have a 1999 grand caravan 3.0 this past wknd i changed my power brake booster . do i need to bleed the sys? my brake pedal is hard when van is off but it gets soft & travel to the floor when on.
Old 08-29-2005, 01:46 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
Re: Brake bleeding
as long as you didn't mess with the brake lines, then you shouldn't need to bleed the systems
Old 08-31-2005, 08:39 AM
Question
why do my brake pedal travel to the floor? master cylinder need changed?
Old 08-31-2005, 11:42 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Brake bleeding
If when you start the car the pedal goes to the floor you either need to replace the master cylinder or bleed the brakes. I would replace the master cylinder and then bleed everything. That may be the reason you had problems in the first place.
