HELP!!! 96 Mustang GT, overheated yesterday on way home. Added water and it cooled down and held. Thought perhaps thermostat was going bad, so replaced it with a 195 degree thermostat (all the parts store had at the time). Replaced antifreeze and went for a road test. All was fine on a fairly hot afternoon.
This morning, cool 79 degrees, overheated again on a 40 mile commute to work. Not bad, didn't push any coolant out, but temp was rising as I sat in the parking lot...Water Pump perhaps???? No visible leaks anywhere!!! Any ideas would help!
Forget World Peace, Visualize Using Your Turn Signals!!! Carl W. Ervin 2008 Shelby GT CSM 08SGT0235 Last edited by motorjock205; 08-29-2005 at 10:34 AM. |
Re: Help with overheatin
Run the car without the theromostat, and see if it over heats.
Could be a pluged radiator. There really is not much to go wrong in the cooling system. If the water is moving, I would rule out the water pump.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
Help with overheating
Well, I know the radiator is not plugged, cause I ran water through it and it came out of the thermostat housing when I changed the thermostat. But, how can one tell whether it is actually circulating by the water pump? The system is totally closed and the only way to see anything is in the overflow bottle at the top, and it doesn't appear to be circulating through there...at least not very much if any.
Forget World Peace, Visualize Using Your Turn Signals!!! Carl W. Ervin 2008 Shelby GT CSM 08SGT0235 |
Is your fan engaging properly? Was the system "burped" properly?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears. |
You should be able to touch the radiator and see if its getting hot, if that is the case the system should be working fine.
Does it get hot when the car is at speed. Or in stop and go traffic? Is the fan working?
Turns out the fan was starting to go bad...it would run for about 30 minutes, then overheat and quit. It also burned the electrical connection going to the fan. Had to replace the fan motor and the connection, now everything is back to normal. Thanks guys!
Glad you got her fixed
better mileage now
Holy Cow Batman! Now that I've got the overheating issue resolved, the gas mileage seems much better now too...checked it this morning after a fillup and got 23.74 MPG...NOT BAD for an old worn out 96 GT!
