Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '93 - '96
Old 08-29-2005, 08:02 AM
winkleboy winkleboy is offline
Battery or Alternator issue? (1996 Passat GLX)
For a while now, the digital clock and trip odometer reset upon starting the car. There's a bit of a lull of energy as i turn the ignition, but then it turns over.
Its increasing in frequency, about 4 out of every 5 times i start the car or so.
It used to do this only about once or twice a month.
I've charged the battery, i've cleaned off the terminals and tightened the cables.
The other day it didnt start at all and i had to jump it.
(Incidentally, the radio stations do not reset: they usually reset when i unhook the battery completely...)
Could i need a new battery or alternator?
Old 08-30-2005, 08:29 PM
boschmann boschmann is offline
Re: Battery or Alternator issue? (1996 Passat GLX)
You might alos want to have the starter checked for drawing too many Amps. It could be pulling down the electrical system to too low a voltage.
Old 09-02-2005, 07:01 PM
rebecca525 rebecca525 is offline
This happened to my passat when I first got it. Almost everytime that I started my car the odometer and clock would reset. The problem went away once I replaced the battery. Hope this helps.
