'94 Voyager 3.3 V6 / PCM replacement questions
As no one here seems to know anything about my problems with this van, I'm thinking about replacing the ECM/SBEC/PCM whatever it is called...
Can I just swap in another one or does it have to be reprogrammed because of the VAT-System ? Does it have to be a '94 PCM or can I also use a '93 or '95 PCM ? |
No one knows ? Please help. I could get a '93 ECM but I need to know if I can just swap it in, or if something like the VATS needs to be reprogrammed.
Re: '94 Voyager 3.3 V6 / PCM replacement questions
Sorry. Not ignoring you just no time to research. Hope this helps....
11 No ignition reference signal detected during cranking (bad Hall effect) OR timing belt skipped one or more teeth; OR loss of either camshaft or crankshaft position sensor. Can cause the engine to stop working entirely with no limp-home mode. |
