Old 08-28-2005, 11:16 PM
tag1240sr tag1240sr is offline
Help-
I was having a major coolant leak right by my upper rad hose. My blazer is a 98 4x4 LS. I have replaced the water pump, upper and lower rad hoses, thermostat, and rad. I have flushed the system. I am now use prestone green. Leak seems to be on the Drivers side of the vehicle.
So I found it was my intake gasket and I have replaced it. Now my blazer wont start. I am getting spark, and fuel. blazer is turning over but won't start. while trying to start sometimes I will see smoke come up from the TB. Tried to reverse the timing and that just gets me a back file popping sound.
Need help. Have to use this vehicle for work.
Old 08-29-2005, 01:10 AM
drdd's Avatar
drdd drdd is offline
Re: Help-
double check your firing order and that the wires are going correctly to the distributor cap
what did you do to your timing? is it 180degrees off?
Old 08-29-2005, 02:47 AM
Re: Help-
I tried it both ways. I have also put in a new battery. I am lost on this one.
