Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-28-2005, 10:39 PM
steviek's Avatar
steviek steviek is offline
Easy to install mods
I have to switch my engine ,.,
and while I'm at it what are some mods that i can do easier while my engine is out?
and what items are the best bang for the buck on an otherwise
stock tsi
other then exhaust system
Old 08-30-2005, 10:10 PM
Eagalicious's Avatar
Eagalicious Eagalicious is offline
I would say the ACT 2100 clutch, upgrade the engine motor mounts and 3rd gen lifters if ya hve the annoying tick sound for starters.
John
Eagalicious's
1997 Eagle Talon Tsi AWD
K&N FIPK
3rd gen lifters, installed
Apexi Turbo Timer w/harness!!! now to install
Eibach Springs coming soon
3" turbo back with straight pipe.
The muffler was the wrong one
Manual BC
1G BoV
The rest is stock but not for LONG!!
Old 08-30-2005, 11:19 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Easy to install mods
John
Stock clutch should be fine.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-30-2005, 11:22 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I think it would be easier to do any kind of work on and engine with the engine out. I would check the timing belt, that would be easier if its out. Clutch and flywheel would be a good thing to do while its out. You could always build the bottom end.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-02-2005, 05:06 PM
steviek's Avatar
I have already had to replace the clucth there's an act 2600
in there.
I do have that annoying tapping noise your right...
Im def going to look into that..
Also is it worth while to change my pistons?
Im not going to have like a 11sec car ever but I do intend to
make it around 300 hp with bolt on mods (FMIC,Fuel pump SAVC 2, headers and stuff like that. Are my stock pistons ok?
Old 09-02-2005, 06:41 PM
cbell77 cbell77 is offline
The stock internals can hold up to and some times even over 400hp. If you want you can replace the head gasket and the bolts might save you a headache in the future. But there realy is no reason.
1966 mustang for sale asking $7900 call 757-766-3702
