Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 08-28-2005, 10:33 PM
speedtriple speedtriple is offline
Oil Smell
If I stop before the car has warmed up - maybe less than 2 kilometers - i get this oil smell when the windows are down - cant detect it in the engine area or if i drive until engine is up to temperature - any knowledge?
Old 08-29-2005, 12:15 AM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Check your PCV lines. IF the hoses are cracked you will smell oil smell in the engine bay.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 09-17-2005, 09:27 PM
limacina limacina is offline
I had the oil smell in my car too. Someone on this forum (Boshman) told me I probabally needed a valve cover gasket, he said the oil leaks out the back down onto the exhaust and vaporizes causing the smell and leaving no sign of the leak.
I added some gasket seal oill additive which attacks your dry seals and softens them. then 1000 miles later, I retorqued the valve cover. I haven't had the problem since. Admitedly, I may have gotten lucky.
It only cost me a couple dollars and was worth trying before changing the gasket.
Old 09-18-2005, 04:13 AM
Re: Oil Smell
Seems thats exactley what it was - the valve cover wasnt torqued and leaked over the exhaust manifold - all fixed.
Old 10-02-2005, 09:22 PM
Re: Oil Smell
Took the Passat to Upstate NY this weekend, 5 hour ride. Noticed the burning oil smell again at a stop light. Theres no substitute for doing the job correct.
I'll have to order up a valve cover gasket soon.
