Old 08-28-2005, 09:43 PM
MazProto1 MazProto1 is offline
Send a message via AIM to MazProto1
Question I got a few Q's, its my turn
yeah hey whats up, first time writter, but ive been reading first. And got some questions for yas about my eventual system that is pretty much put together now....in my head. For the front i what to go with CDTcomps the EF-61cf 05. And as for the sub im going to get an re SE-12. Do you think this will be ok when it comes to matching the fronts to the rear sub? Will that be enough mid/midbass? Also the sub will be in a ported box (NG hook it up). What amp should i get for the sub, lets say $300 at the most and under (perferably under) including shipping. I am going to be using the caughstockcaugh HU. So where can i get that device,,, i forgot what they are called. its to take the rear signal wires and splice or connect them to this device, and then to the amp? Now as for rear fill which i would want because some of my songs include them, if that make sence. I was thinking of cl-6x, and by the way is this a 6" or a 6.5" speaker? is it 80 watts max or rms power handleing?
Thanks
Old 08-29-2005, 10:07 AM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
Re: I got a few Q's, its my turn
if your redoing eerything, jsut get a fucking aftermarket HU, even a low-mid level one. for cheap yet reliabe amps id look @ profile or hifonics.
Old 08-29-2005, 05:02 PM
Re: Re: I got a few Q's, its my turn
yeh your right about the hu, but the only problem i had was that my headunit was an akward size and i didnt want no one to notice anything.
As for the amp would a profile cl600m be ok and for hifonics what amp would you suggest. Also is http://www.audio-warehouse.com an ok place to buy it from?
Old 08-29-2005, 08:50 PM
dude, slightly protruded afetermarket HU beats a flush stock anyday. i dont know about that site, never used it.
profile and hifonics are both very nice amps
Old 08-29-2005, 11:29 PM
na its not that about it protruding out that dosent bother me its just that my stock hu is like 7.5" by about close to 5" high. which i hope will be the right length. but what im sayn is there will be a hole underneath the hu. Is there like a cover plate or somthing i could get to cover it.
Old 08-30-2005, 07:11 AM
i know ive seen kits that leave you a lil sotrage pocket underneath. if i were you i would get a 1/2 or 1 din eq to put underneath.
Old 08-30-2005, 10:42 PM
Ok thanks ironicly i had just noticed those kits at walmart while i was passing by but they dont seem to have the one for my car. i guess ill have to check somewhere else. I know your talking about an equalizer but what would 1/2 or 1 din stand for.
Im definataly going to go with an after market hu now. But i have another question about my systems rear fill, how should i wire it? If im going to use either ef-61's 120rms or ef-61cf's 150rms should i put cl-6x's (i dont know if its 80w rms or peak) and just run them off the hu if it was 50wX4 (which will probably be 25 rms or so would this be enough for them, or loud enough) or should i use a seperate 2 channel amp for them.
Old 08-31-2005, 07:37 AM
everything depends on how much $$ you got. hit me up on aim and i can help you out more.
Old 08-31-2005, 09:34 AM
tr10av tr10av is offline
Send a message via MSN to tr10av
If you buy your head unit off of www.crutchfield.com. They will supply you with the wiring harness, mounting bracket, that storage pocket, and instructions specifically for your car. AND best of all that is all free with your purchase.
DIN is the basic industry standard size of an aftermarket head unit.
'87 Chrysler NewYorker
2 12" Ascendant Audio Assasins in Sealed Box
Hifonics TXi 6406 Bridged to 2 Channels
VR3 CD/MP3 Player
COMING SOON:
Component Set
Amp for components
Old 08-31-2005, 10:09 AM
^^ even if you dont buy your HU from there, they can usually suplpy the brackets n stuff, but i buy all the HUs fro my installs from them, unless i find and outrageously good deal elsewhere.
Old 08-31-2005, 10:28 PM
alright cool i was wondering where i could find the brackets from ill have to check that out.
Old 09-03-2005, 09:12 PM
http://www.onlinecarstereo.com/CarAu...roductID=13114
Is this amp right to power a SE-12 i know it needs 600rms but if this amp is putting it out at 4ohms is that ok if i wire the sub in series? Any other suggestions on amp, or on wireing if the amp is right fill free to wright. Please help.
Old 09-04-2005, 09:53 AM
http://www.onlinecarstereo.com/CarAu...roductID=14798
that will give you 700 watts @ full power
i would go wit hthat, its a lil cheaper an its gonna let you get a lil louder when your showing off.
Old 09-04-2005, 12:31 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
Check out JBL GTO600.1's, Kicker Kx600.1's, and MTX TA5601's.
2002 Ford Explorer Limited
D31 yellow top
Kenwood DDX-7017
2 Ascendant Audio Avalanche 18's
13 cuft NET ported box tuned to 27hz
Autotek Mean Machine MX3000.1
Ascendant Audio Arco component set
Orion 275SX (Mids)
PPI Art Series A200 (tweets)
Poly Mids for rear fill to come soon.
Old 09-04-2005, 08:11 PM
thx, i think i wil go with the hifonics one though price wise.
